what need to be changed??
when adding a lift of any sort like a 3in or 3.5. what needs to be changed in order for it to fun correctly. for example, do i need to change my drive shaft or change the gearing?
For example: I need a 3 inch lift and I only go offroad when there is a lunar eclipse...
= Well it's safe to say an entry level 3 inch lift should do the trick for you.
Another example: I go offroad everyday and have already replaced my 2 axles to Dana 60's with ARB lockers. = This example explains the other full extreme of the equation regarding the question posed.
My point is that there is a ton of information regarding your question and a bunch of these answers can only come at your assumptions for your jeep regarding these needs..ie offroad/onroad manners - swaybars disconnected everytime off road, 33"-37" in tires, perception of power, places you wheel, etc...
You'll only need to regear if you change your tire size and that need is only based on your expectation of acceleration on road off road etc..... I know this isn't being at all helpful but there are a few questions you need to answer before our opinions can help sway you decisions.
A typical needs - 35" tires are usually accompanied by a gear change regardless of lift size (lift has no effect on gearing) to regain the perceived lost power with the tire diameter change. A 3-3.5" lift when used to it's fullest capability on a 2dr or 4dr will have an effect on your driveshaft needs. Auto or Manual all have an affect on you driveline needs when lifted... Give us a scenario on your perceived offroad needs and your expected tire sizes along with the auto/manual 2dr/4dr breakdown and you'll get plenty of lift/gearing ideas.
Good luck...
I bought 35 in tirers and bout to buy lift. What I was lookin for is the changes to the trasfer case and the drive shaft. Also does every lift need to change its gearing.
Originally Posted by NJ-RUBICON
My jk is a 6 speed and I.plan to do off roading very often
