What Else Do I Need For the TF 2.5 Coil?
I don't know much about lifts...Is this kit complete? Do I need to order the stabilizer? I have a 2012 looking to clear 35s.
do a little search for the 2.5 lift. There are tons if threads on it. But for the most part its a "complete" kit. I would order at least the front adjustable track bar to start. A stabilizer isn't needed if your suspension is dialed in correctly.
JK-Forum Founder
complete enough and you don't need a new stabilizer. the factory one is better than what you can buy anyway. if you get new longer shocks with this kit, make sure to get exhaust spacers. you might want to get a front adjustable track bar as well. not needed but, it will allow you to recenter your axle.
