What does it mean when someone says
Ur front gears (5.13) have doubt the backlash they r suppose to have.
What is backlash
And
How much is it suppose to have if any
What is backlash
And
If you hold the pinion gear, and rotate the ring gear back and forth, the amount it moves without moving the pinion gear is backlash.
I can give you the numbers for the stock gears. Don't know if your after market gears are different. Seems like those numbers would be supplied with the gear set.
