What do you recommend?
I want to put a good sounding exhaust system and a CAI. Maybe some sort of computer chip it it doesn't mean I need premium. I also want a winch. Thanks.
T-Max are great and WARN for winches. Make sure to do your research and don't settle for cheap. Advice is to look for in a winch - not just the maximum pounds it can pull (for example 9000 pounds) but what the winch can pull after each turn. Some winches will signficantly loose pulling power after revolutions.
I have an Airaid CAI and a relocated Magnaflow muffler, similar to the Cool Tech set up, but I only paid $100 for the muffler (Stainless steel Magnaflow, Summit $88 + handling). One of the local shops was going to charge me $40 to weld the muffler in and make and install a tailpipe (got it FOC). So most anyone should be able to have it done for around $150. I'm just relocating the factory heat shield also.
I considered going with a T-MAX winch and decided not too. They are now manufactured in China. The Warn winch itself is made in the US. I did discover there are a few parts for Warn are made in China. (Clevis hook, remote control assy and mounting hardware)
Pete
