What do I gain from a long arm lift?
#21
Former Member
The benefits of long arm kits are pretty obvious nobody will really dispute that. They are a big commitment, with the grinding off factory brackets because once you go long arm there's no turning back.
In my opinion it sounds like what you are going to be doing with your Jeep you shouldn't need a long arm. I would think with what you currently have on the Jeep it should be able to ride and handle like stock if not better.
I would make sure everything has been adjusted correctly, check the track bar bolt because the hole wallows out easily.
If you want to go long arm you do not need to scrap most of what you have, most companies already mentioned sell Long arm upgrade kits.
#22
Do yourself a favor and call Dave at Northridge 4x4. I have a 4" SuperLift on my 2dr. I have very flighty steering and my ride quality is horrible. Dave suggested I go with a complete 4" Full Traction long arm lift kit. He said this long arm kit will give a great ride and eliminate my steering issues. Once I get the cash, that is what I am going with.
#23
Sponsoring Manufacturer
So if you already have a 4" lift on your JKU that's not a long arm, I bought mine used, you should scrap the whole lift & buy another one? That seems a bit extreme.
I saw the Teraflex kit, which I assume would be of great benefit, but are most of you saying to scrap your current lift??
![](http://www.teraflex.biz/media/catalog/product/cache/2/image/9df78eab33525d08d6e5fb8d27136e95/f/i/file_46_7.jpg)
#24
For the rest of the readers let me explain why. Another way to drastically simplify the complicated geometry issues induced by lifting a Jeep into something easily comprehensible, is to state one simple rule. The closer your arms and track-bars are to horizontal the better your ride will be. The farther the arms and track-bars get from horizontal the worse the ride and handling, and the more susceptible you are to death wobble.
Stock arms are horizontal from the factory, as you lift a Jeep more and more the arms begin to angle farther from horizontal. How much lift is enough to affect handling? Typically anything 2.5"+ will begin to affect handling and ride and the higher you go the worse handling gets. For the mathematicians, the impact on handling as you continue to lift is not a linear function, or in simple terms, the first 2 inches of lift have barely noticeable handling impact. Add another inch and the impact of that additional inch on handling is greater than adding the previous 2 inches. As each additional inch is added, that new inch impacts handling to a greater degree than the previous inch. Various adjustable components already talked about help minimize the impact to handling and ride but do not totally eliminate them.
Now an easy second rule. The longer an arm the less it's angle from horizontal changes when applying the same amount of lift. This is why Long Arms are beneficial, they reduce the angle and make the arms more horizontal.
As a general rule, most companies say that the benefits of a long arm lift begin to pay off in a major way with lifts above 3 - 4". That is not to say that a shorter lift will not benefit from long arms, just not as much. The higher you lift the more long arms will benefit your ride and handling.
#25
you guys got me convinced. i foresee a long arm upgrade in my future. (although, i have no complaints on ride quality now. it is just as good or better than stock).
#26
I'm not disputing the added benefit of the Long A, I don't doubt one minute that it drives better than stock,,, what I'm sayin to the guy is that if he's open to spacers to give that a try first b4 the 2 grand for the upgrade kit,, if I was goin to stay 35's, I woulda went with what I have (4" stock arms, and 1.5" wheel spacers) the thing drove very straight and tracked very well. 220 bucks vs. the 2 grand + labor unless ya do it yourself,, I would do the spacers see if I could live with it. It drives good with 40's and 1.5" spacers, tracks straight down the hwy,,,,
#27
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
I totally agree with the spacers. Get a wider stance and out of the grooves in the road. I was also stating if you haven't bought adjustable short arms, instead of buying adjustable short arms jump up and buy the long arm kit. I need to get out and wheel with you some time soon the see that Jeep on 40's now. I'm kind of kicking myself for not going with 40's. I love my 37's though!![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
#28
Thanks all for your input!
A bit more info from my side: the Death Wobble was fixed (was caused by bad ball bearings and worsened by a bad SS).
I also have pretty wide tires: 12.5", this does not help.
Interestingly enough speed is a small factor in the on road behavior of my Jeep. The other day I drove back from France (European Jeepers Jamboree) and had no issue to drive 75 mph all the time (besides the speeding tickets). I.e. the Jeep behaves ad bad drive 50 mph as it does driving 75 mph. It just feels insecure and wanders a bit. And any bump and pothole feels like the axle is heavy and jumpy
The issue I have is that every time I see a new solution I end up further down shit creek... I was told I should fix the caster; the JKS LCA's should have fixed that (caster is close to the stock situation). Nope! I should realign my axles by using an adjustable track bar, hence the JKS adjustable tack bar. Nope! I should do a little dance before getting in the car. Nope!
Don't get me wrong: i love my Jeep. And I have no intention nor the funds to trade it in in the foreseeable future. So I am willing to invest some more in the suspension (and postpone those lockers and regear I was dreaming about). But since I already bought the LCA's and Trackbar, an upgrade kit doesn't save me a lot of money. If I am throwing more money in this flawed suspension, I want to do it right this time. So I get a Jeep that drives good off- and on road!
#29
Hey Niels,
U don't know me , but I live in Holland also.
I have on my JK the 4" Teraflex Long arm lift and performance realy great.
If I was u I should consider the Teraflex 3" L.A. if u decide to stay on the 35" tyres, what's big enough here in EU
I was not on the Jamboree but on a private terrain in the south of France last week cause the Trophee Cevenol was canceled and drove my Jeep more than 2300 km with a average speed off 75 mph with 37" tyres.
![Blush](https://www.jk-forum.com/forums/images/smilies/blush.gif)
#30
I do question my skills since long ago :-) so I went to various shops; to no avail!
