What do I gain from a long arm lift?
You get baller status
I have the FT long arm kit and it rides extrememly well and feel tighter than stock when turning which is nice with the 3in of lift I added. Havign adjustable control arms and trackbars will help return the geometery back to stock which should be your primary goal in maintaing stock ride and handling characteristics.
That pre-runner kits performance is impressive. I would assume it would give equivalent performance on the highway as stock?
As for the wobble wows, thats kinda wierd as I installed the 2.5/3 level kit with extened track-bar brackets and shock extenders and ride quality did not "suffer" per say. The only issue I experience was when I installed 315 Hankook Dynatrack (certainly not saying they are a bad tire by any means) and sudenly when I hit any crown in the highway it started to steer like a walmart grocery cart! I immediately went back to my 33's. I since added a 1 body lift and 5:10's and put on 315 MT Mud ATZ's and for the first two days was white knuckling it wait for it to dance with me. Surprisingly, no issues.
I just came back from the European Jeepers jamboree and noticed that the most "agile" jeeps have long arm lifts. I currently have a 2-3" OME lift on my 4dr X and do not experience the "better than stock" drive others claim they have.
Been through various episodes of death wobble and while being "in stable condition" now, I don't like the drive quality now. I just feel how heavy my (meager) 33" are on the axles. Every little pothole is another adventure. Off road flex is sufficient however.
Which makes me think: should I switch to a long arm lift? Something like Off Road Evolution MFG JK 4" DoubleD Bolt-on Long Arm Kit (if I can afford it). I am hoping the long arm lift does restore the original geometry somewhat, hence returning stock quality drive-ability. Being in Europe I do little rock crawling, mostly sand, mud and a lot of highway.
My next set of tires will be 35's. A (real) 3"-4" lift will do for me.
Anyone made the switch from short to long arm and what are your experiences? What should I do? And which long arm lift do you recommend (and why). Do I need anything else than the above mentioned kit?
JK Forum Regional Rep
Thats where we are at,deciding on long arm or short.Finding many folks prefer long arm.I've found 2 companies that allow you to use your current lift and add these kits without spending money on a new kit.Full-Traction and Tera-Flex offer these kits,good for both 3-4 in lifts,price about the same
So, what you are all saying is that. To get an equal or better then stock ride with a 2" lift, you need a long OR short arm kit? Is that right? Because it suddenlty means you go from a moderate budget 600$ kit to an 2500$ or so kit !!
In the research that I have done long arm kits will do nothing for lifts of 4" or less. There is a thread about this already (much bigger) where several manufactures have said straight out that the arms on a JK are plenty long enough for these lifts and no gain in ride quality will happen (but you will see other benefits) with a LA kit. You might want to look to your shocks or control arms for a problem.
Do yourself a favor and call Dave at Northridge 4x4. I have a 4" SuperLift on my 2dr. I have very flighty steering and my ride quality is horrible. Dave suggested I go with a complete 4" Full Traction long arm lift kit. He said this long arm kit will give a great ride and eliminate my steering issues. Once I get the cash, that is what I am going with.
Former Member
Why don't you drive my 3" long arm two door and see for yourself
So if you already have a 4" lift on your JKU that's not a long arm, I bought mine used, you should scrap the whole lift & buy another one? That seems a bit extreme.
I saw the Teraflex kit, which I assume would be of great benefit, but are most of you saying to scrap your current lift??
