what could it be?
Old 05-21-2010, 05:04 AM
Default what could it be?
So I have just put on my 4.5" BDS short arm lift. I do not have adjustable control arms or adjustable track bars. The lift when on smoothly. Then on the way home I felt a little bit of shaking, so I went and got my tires re balnced (35's) and got an alignment. Now everything rides really well until I hit 65 MPH. From there on up it shakes. I can feel it in my seat and in my feet. I ordered adjustable track bars last night. I just wanted some input on what you guys thought it might be. By no means is it DEATH WOBBLE! It is minor shaking that is REALLY annoying. Thanks for your help fellas.
Old 05-21-2010, 05:08 AM
GoodysGotaCuda's Avatar
are stock driveshafts on your rig supposed to be good with that much lift?
Old 05-21-2010, 05:19 AM
well when I'm driving on the road it didnt seem close the guard at all. That is a possibility though.
Old 05-21-2010, 09:05 AM
does anyone know if the driveshaft will make that much of a difference?
Old 05-21-2010, 10:31 AM
dadgummit's Avatar
With a 4 door your rear shaft is going to be ok on the road your front is hating life right now. Why not try removing it for a day (very easy) and seeing how it drives. That should tell you right there if there is a problem.
Old 05-21-2010, 10:34 AM
Calypso's Avatar
Oh yea
Old 05-21-2010, 01:24 PM
Will this hurt anything at all?
Old 05-21-2010, 01:45 PM
Coley's Avatar
You're just physically removing the ability to put it into 4wd. Won't hurt anything.
Old 05-21-2010, 04:55 PM
Thanks for all the input!
Old 05-21-2010, 05:17 PM
VaNomad0530's Avatar
I've actually been having the same issue. I have the same amount of lift with 35's. I'd love to hear what anyone may say. Same deal, everything went smooth going on and tires were balanced before the install. Only a slight amount of wiggle in the steering at higher speeds. Still makes me paranoid tho. I'll definitely be following this thread.
Quick Reply: what could it be?
