What to check for-lift.
Old 01-01-2011 | 03:02 PM
Camojeep's Avatar
Default What to check for-lift.
I just installed a 1 3/4 inch Daystar spacer lift in my 2 dr JK, anything I should watch for a problem? I seen talk on the forum of driveshaft/skidplate problems. I don't use the vehicle hard, only light off-road use.
Old 01-01-2011 | 03:55 PM
nthinuf's Avatar
Assuming the install was good (all components loosened, spacers installed, all components torqued to spec while on the ground with vehicle weight on), you shouldn't have any issues at that height. Driveshaft problems on auto's generally start around 2.5" if you disconnect and have long travel shocks. Shorter shocks and no disconnecting, you may be ok to 3.5 or 4 or so.
Old 01-01-2011 | 04:20 PM
sa29560's Avatar
Everything should be ok till you decide to get a nice coil lift.
Definitely nice to get a little height for only a tiny bit of coin though, nice JK
Old 01-01-2011 | 04:57 PM
JayhawkJeep's Avatar
Veteran: Navy
You may now have to worry about more people starring at it due to it looking more bad ass.
Old 01-02-2011 | 01:55 PM
Camojeep's Avatar
Default Lift questions
Thanks for the info. I had the front end alinement ckecked at a shop, and they said everything looked OK. Its is a auto, and I have seen where there could be a problem with the front driveshaft. I didn't think 1 3/4 would be that bad for driveshaft angles.
Thanks again for info.
