What is this? It came with my winch.
i would call superwinch and see what they say
Looks like some sort of fuseable link to me. Its purpose is to actually melt and break the circuit if it happens to get overloaded and get hot. Odd thing to have on a winch set up. Especially under the hood directly connected to the battery pos. teminal.
Here is what it looks like once you install it.
Just don't get your Jeep up to 88 mph after you install it or this could happen.
God knows where you'll end up.
If you ever do, you know you're prepared. Seriously though, those are not fuses. They're circuit breakers. One side is for battery and the other side is for.....well.....whatthehellever. Why it came with your winch is really a mystery. None of them would be enough to hold all the amperage of the winch....not even all of them together.
The way that they designed that thing is odd. It leaves a lot that can arc on something. Make sure that where you put it there is no metal or wires for it to bump. Those plates and bolts will all be hot, so keep them away form anything. If you can put the whole thing over the plastic top of the battery, it would be a good start, IMO. Good luck!
BTW, what do the individual breakers have stamped on them?
Definitely circuit breakers. See this article for more information:
off-roadweb.com/tech/0803or_superwinch_x_s_series_trailer_winch/index.html
Or here to buy a replacement:
store.summitracing.com/partdetail.asp?part=SPW-8932332
There isnt one in the solenoid box (I know, I have had mine apart A LOT due to the fact that I added my own wireless BOX and relocated my solenoids to in the engine compartment.) It is a CCT Break/Fuse. It also came with my 8500. It is in the instructions that you mount in on the pos side. I have also seen guys run without them. I have mine mounted and there are no arcing issues.
