What bedliner?
What bedliner?
Want to bedline the trunk area of my jeep.. And maybe the area under my doors ...all I can find is the herculiner one ..is this good enough ?does it last?.. Should I look for something else.. How much should I buy will a gallon be enough?
Thanks
Thanks
There are a bunch of threads on Herculiner if you use the search tool. I personally did Herculiner myself for the entire floor of the Jeep. 1 gallon will last for the whole thing. It's supposed to be able to do a 6 foot truck bed, so you'll have plenty. I've had mine on for over a year and I love it. Only thing that sux about it is that it has VERY strong fumes when you first apply it that will last about 2 weeks. Best time to do it is during a really hot day with high humidity to assist with the curing process...and no I'm not F'ing with you. Make sure you do it in a well ventilated area with your top off too. I did mine on a hot day, but it wasn't that humid outside for about another month or so. I would do it and then ride around as long as you can with the top off. If it rains...well...just open your windows up!
Long and short. I love it. Affordable, easy to do, and it really lasts
A lot of us have used UPOL spray liner with great results. If you have an air compressor it is an option. A different texture than heculiner or line-x. Bedliner is a great mod but several days work to do it right. I have bedliner and husky liners also. The carpet is now stored in my basement never to be installed again.
I did mine last July in the carport, and the doors and windows were off for a few months afterward anyway. That stuff is tough!
With the $99 kit, i got 2 brushes, a stirrer, and a tray (forget the roller). It took a few hours to "dab" it on, but it covered the whole tub twice over, and the front wells 5 or 6 times.
PREP WORK IS KEY!!
..and disconnect your battery before to undo any seat wiring.
...or you could pay somebody else
I am doing the herculiner tomorrow. All my seats are out now, and the inside is prepped. just need to do the final clean, tape and roll / dab it on
wilywillie, do you have any pictures of it re-assembled? How were the fumes after you did it?
