Ways to truly increase engine power or is the jk pentastar just that good?
#21
I agree with things that you say in this post. However... I don't see why Chrystler doesn't have at least an option for a bigger engine. With people dropping 6K for a supercharger or 20-25K for a V8, why wouldn't Chrystler do something similar.
And the main thing that I want would just be lower end torque. I used to have a ZJ with a 5.2 that could pull trailers in the dunes. My JK can't pull itself through the dunes at the same ability. But I do agree that it's impressive to see a Wrangler get up to 22 MPG, where as the previous generations barely got 15-16
Also I should note that I have the slowest Pentastar I've ever been in. I think I just ended up with a bad one. My buddy with the same 35" tires and 3.21 gears is substantially faster than mine, which has 4.10 gears. And I recently drove a 2013 with 37s that kills mine in power as well.
You can order the entire HEMI ENGINE SWAP directly from your dealership (via MOPAR). It's roughly $15k for the 5.7L, and $18k for the 6.4L -- and that's just for parts!
And what do you mean that your buddy's jeep with the higher gears (3.21) is "faster"? In what way?
#22
After researching bolt-on power options short of a SC; the number one recommended mod seems to be gears. So, I had 4:56 installed along with AEV lift and 35"s at the dealer. The gears cost about $1,500 out the door. I noticed quite a jump in power, especially off the line. Considering the increase in offroad performance as well, I'd say go with gearing first for the biggest bang for your buck.
#23
Former Vendor
I picked up an 08 2 door over the summer that needed a motor and I am building that one out to be a wheeling rig that I don't mind tearing up. I wheel my JKU, but there's always the lingering notion that I'm destroying a $50K+ vehicle.
/hi-jack
I couldn't agree more with those that are saying a re-gear will do more for instant return on power gains than anything else. A supercharger without the right gears won't be as exciting as one with the right gearing for the tire size.
Marcus
#24
#25
Chrysler does offer a v8 option -- it's just ridiculously overpriced.
As for MOPARs V8 conversion, I was completely unaware of that. Though I would wait to see if the diesel comes out before I pulled the trigger on engine swap options.
Oh did I say "higher"? I guess I meant longer ratio. But yes, his Jeep with same tires on 3.21 gears will out perform my Jeep with 4.10s in every way. Our Jeeps are practically clones other than his paint matched fenders, so I know it's nothing to do with weight. Also just last week I took a ride in a 2013 on 37s and that thing was a racecar in comparison to mine. In fact, his felt faster than mine did of the dealership floor with stock tires and all. So I've come to the conclusion that I have a crap pentastar.
#27
Not sure if this is the issue you may be experiencing.
#28
I get what you're saying and I appreciate your help, but I have a good amount of experience with gearing and it's affect on vehicles. I had 3.21s on my JK before and went to 4.10s with a noticeable difference in "off the line" power. But it's still less than any other Pentastar equipped JK I've ever been it. I just have to suck it up and realize that my Pentastar is a fail and needs to be supercharged
#29
#30
