way to many wires going to the battery
Comes just like that, they are used on boats, and I know a lot of boat builders that swear by them. Search Slue Sea Systems ST on amazon. Mine is the six circuit with cover and negative bus. 34 bucks.
The sPod and the OnyxBox are fused relay boxes. All the electrical load stays under the hood and only activation wires are run to the switches, which is how you should do it. The Blue Sea System is strictly a power distribution system, like an auxiliary fuse box. Reason the BSS is so much more affordable, because your relays are not integrated into the system.
I could use some help it's beginning to look like a hot mess under the hood, and with an onboard air compressor getting mounted soon, I am running out of places on the battery.
I remember seeing where people are mounting terminal bars under the hood but can't seem to find a link anywhere. At the the time i never thought I'd go this far down the rabbit mod hole.
Any help would be appreciated.
I was able unload a ton of wires/relays etc under hood once I installed an spod. costly but well worth it IMO.
