way to many wires going to the battery
I could use some help it's beginning to look like a hot mess under the hood, and with an onboard air compressor getting mounted soon, I am running out of places on the battery.
I remember seeing where people are mounting terminal bars under the hood but can't seem to find a link anywhere. At the the time i never thought I'd go this far down the rabbit mod hole.
Any help would be appreciated.
I could use some help it's beginning to look like a hot mess under the hood, and with an onboard air compressor getting mounted soon, I am running out of places on the battery. I remember seeing where people are mounting terminal bars under the hood but can't seem to find a link anywhere. At the the time i never thought I'd go this far down the rabbit mod hole. Any help would be appreciated.
However I did buy a large busbar that I could have just as easily mounted inside that same box and accomplished what you were looking for
Orangedue71 has a nice clean box that's fused and insulated. Perhaps he can post a parts list for repro.
Firstly decide if you need a distribution block, a fuse block, or some combination of the two. BlueSea makes great products that you can get from Amazon, I saw a fuse block on sale this morning.
Buying a terminal bar depends on what you plan to connect to it, they have current limits so buy one that's right sized.
It might be a matter of just replacing your battery terminals with marine terminals and using a longer bolt, which also gives you a hex head instead of 4 sided.
This pic is old, I have more of those 2/0 welding cable connections now, just replaced the bolt and cinched it down.
BUD Industries NBF-32008 Plastic ABS NEMA Economy Box with Solid Door, 10-5/8" Length x 3-59/64" Width x 2-3/4" Height, Light Gray Finish https://www.amazon.com/dp/B005T7Z75C..._SDi9wbMP577KS
Is the box. That's kind of key because there isn't a lot of space between the battery and hood. Then I used a dollar sheet of scrap abs from tap plastics in the bottom. It's about 1/4" thick. The great part about that is that I could use a pilot hole and a wood screw for mounting everything down to that plastic. After that, you can put whatever your heart desires in the box safely. And then I used a fuse tap to power the relay. I'll put some Velcro on the bottom but it really can't go anywhere.
This is an example of the Blue Sea parts on sale, it will be on a lightening deal this afternoon for a while. I have great experience with these, everything is rock solid. Plus if you have an issue just call them and you'll speak to a guy in WA state. I was able to twist off a lug and since the products are warranted for life, they just sent me another in the mail no questions asked.
Blue Sea Systems ST Blade Fuse Block - 12 Circuits with Negative Bus & Cover
If you buy anything from Blue Sea, Bussman or Hella, you'll be fine. I mounted my fuse block on to the top of the main fuse box under the hood, just bolted on. For me it's fine there and very convenient.
Check these out:
Bussmann (CB185-100) 100 Amp Type III Circuit Breaker
Blue Sea Systems DualBus Plus 150A BusBar - 1/4
OLS PSZACCEPS052H 10-Way LED Illuminated Blade Fuse Box with Cover
Check these out:
Highly recommend the Blue Sea Systems Bus. Very High quality, and keeps things pretty neat under the hood.
Attachment 641937
Attachment 641937
