Warning, Superior Axle Studs
I took my JK into the shop to have my 5.13's installed and asked my mechanic to install the rear Superior axles I ordered while he was at it. He called me this afternoon and told me the wheel studs that came with the axles were too short for my Spidertrax 1.5" spacers to be bolted back on. He's going to call Superior tomorrow morning to see if they make them any longer. Superior uses a stud that threads into the axle making them hard/impossible to find locally. So if you're planning on some Superior rear axles with your spacers, contact Superior first or stay tuned to this thread. I'll update here as soon as I hear anything.
Funny I'll have to check but I just installed Superior axels in my rig and the studs didn't seem any shorter than the stock ones. What I have heard is that since the Superiors thread in, there is a chance that when tightening the lug nuts you can back out the studs and fawk up your brakes.
As to backing out I'd think putting some red Loctite on the studs would prevent that from happening. Blue would probably work too. I was going to inquire as to the torque specs for them also. I take my lug nuts to 95 pounds; it makes sense that the studs should be higher - maybe something around 125. A call to Superior is in order; or perhaps David knows.
Good luck Seer1 on getting this rectified.
My people called Superior's people and they, of course told my people they'd never heard of this before. Lance (the guy putting in my gears and locker) and I had a bit of a chuckle about the number of times we've both been told that by various vendors. Anyhow they're shipping longer wheel studs out (on my dime) and they'll hopefully be here tomorrow. So check the stuff before you pull everything apart.
