WARNING to LubeLocker users!
Old 07-08-2009, 07:30 PM
  #21
opdsgt's Avatar
Originally Posted by tkob1060
they can NOT respond to this thread without signing up as a sponser
I think they'll get black listed if they do
I've been using LL and Solid diff covers with out a problem, always followed the torque for the solid covers
I haven't read the FAQ closely enough; I thought they might be able to weigh in with a non-commercial response.
lol, I know full well people are getting away with 35 pounds on those bolts. Living on borrowed time methinks...
Old 07-08-2009, 07:32 PM
  #22
opdsgt's Avatar
Originally Posted by Hellbound13
Woah, wait... I can't get a socket on the factory bolts? Are you just taking about with a solid diff cover?
Right. You can't get a socket on a SOLID cover with factory hex bolts, that's all.
Old 07-08-2009, 08:02 PM
  #23
cojk's Avatar
Default Lube Lockers
When I bought my Riddler covers from Northridge, I sent Dave an email regarding the issue reported. He suggested to use a 6 inch ratchet and make the bolts snug. I have had no leaks and no broken bolt issues.
Old 07-08-2009, 08:41 PM
  #24
RedneckJeep's Avatar
I've always just gone for 25 LB FT on 5/16" bolts and called it a day. I would say you should write to the makers of Lube Locker. I think this is a legitimate concern.
Old 07-09-2009, 03:32 AM
  #25
opdsgt's Avatar
I agree Redneck, and I've done exactly that. We'll see if they contact me back or are able to make a comment here. (If they e-mail me directly, I'll post what they say.)
Old 07-09-2009, 03:48 AM
  #26
pearl-drum-man's Avatar
Thanks for the heads-up, I intend to go with the gaskets whenever I get around to doing the covers.
Old 07-09-2009, 05:08 AM
  #27
Okay, so where is the real problem? The Solid Diff Cover, the Solid Supplied hardware, the lubelocker itself or the lubelocker instructions? I am not really sure how to address then when I change mine next week.
Old 07-09-2009, 05:11 AM
  #28
paramaniac's Avatar
my personal experience is
a) the SOLID supplied hardware
b) the instructions supplied by Lubelocker
the combination of the two is bad news
Old 07-09-2009, 05:30 AM
  #29
bostonMA's Avatar
I will put in another plug for the wrist torque. Used a 7" Allen and got the hex bolts snug the first time through. I then went over them and got them as tight as possible without using my bodyweight for leverage. I figure this puts me around 25 ft-lbs.
I have ARB and have checked the gear oil level 3 times in the last 2 months. Haven’t lost any yet.
Old 07-09-2009, 06:17 AM
  #30
opdsgt's Avatar
  • The SOLID diff covers are fine. Good stuff.
  • The SOLID supplied fasteners are satisfactory so long as you don't go anywhere near the LubeLocker recommended torque setting; stainless is significantly softer (read: easier to break) than Grade-8 stuff.
  • The LubeLocker gaskets are fine. Good product.
  • The LubeLocker recommended torque setting of 35 lb-ft is whack. Period.
Make sense?
Quick Reply: WARNING to LubeLocker users!
