Warning Light Brake
Over the last few weeks on my 07 JK my brake light has been coming on at random times. It dings and the word brake appears in my dash for a few seconds then it will go away. I have no idea where to start looking. I thought that light dealt with the emergency brake and it is not engaged. Any thoughts
![](https://www.jk-forum.com/forums/images/ranks/veteran_navy.png)
Also will come on if you have issues with your ABS system. The brake light does indicate the parking brake is on but the main purpose is to let you know there is an issue with the brake system.
R/
Will
R/
Will
I've been searching my brake light issue for awhile now. Check fluid level in the reservoir first. Then check the fluid level sensor on the side of the reservoir. Mine was faulty causing the light. I still haven't ordered one yet as my jeep is going to the dealer for the airbag recall on Monday.
