Is the Warn VR10000 a Centered Winch
Hi All,
Before anyone flames me I've used the search function and haven't turned up anything.
I have a 2015 Hard Rock bumper and am going to install a VR10000 on it but I need to know if I need a centered or off set winch plate, any help would be appreciated!
Not really sure if you're asking about how it lines up with a bumper or fair lead.
If you have those stock stamped steel bumpers the zeon winches which are centered do fit but it is a tight squeeze. Some bumpers require modification to run the zeon.
With the m or vr series winches they are offset with the gearbox all on one side with the solenoid.
Both different front bumper I've rocked had multiple mounting positions on the winch plate to account for the different setups.
Thanks. I have the stock Rock Hard/X/10th bumper, and I need to order a Mopar winch fairlead adapter. They offer a centered and off-centered adapter--does this mean I need the off-centered plate?
Go to the Maximus III site and look at their mount. They do a much better job explaining the winch fitment.
