Want to run 38's
Old 10-17-2011 | 07:02 PM
popo343's Avatar
The first pic shows my 38s at full stuff when testing out. At the time of this pic I still had the stock upper and lower. I did have to cut 2 inches of the slider and some cutting front and back of the o the tire on the wheel well. The front wheel had to be cut behind the tire. The second pic Is just a ref.
ID:	225018   Click image for larger version
Old 10-17-2011 | 07:05 PM
NJ-RUBICON's Avatar
What lift r u running
Old 10-17-2011 | 08:24 PM
popo343's Avatar
The started out as a 3in Blk Diamond lift. I have since added RK front upper/lower CAs. When I added the tires I added the 1.25 Rough Country BL. I will be adding the RK Tri Link in the rear in a couple of weeks. I want to keep a LCG but may switch out the coils for 3.5 RK springs later down the road. It all depends on final clearance after I install the rear bumper Im building.
