Want a pic of a 4-door with 2.5" spring lift, 35" tires and Bushwacker flat flares!
I'm struggling with the decision on whether to go with flats. It may depend a lot on tire size and lift. I have the TF 2.5" spring lift and 35" tires. I think the tires look just a little tight right now, so it could be just right with flats... or it could make my tires look dinky.
No pics, but you'll be happy with that setup. You'll get much more flex out of your 35s/2.5 with flats. You may need adjustable rear lowers control arms or trim the pinch seam behind the rock rail.
Here is mine. I love the look and ride.
2011 Unlimited, RUBICON, 2.5” Teraflex coil lift +shocks, 1” teraflex front spacer, 17 x 9 XD black SPY wheels, Taraflex adj. front track bar, JKS rear track bar, 35x12.5 Goodyear MTR, 4.10 6 speed, Superchips FP, Mopar extended Rubicon rails, Mopar Sun bonnet, LOD front and rear bumpers with tire carrier, crown extended front brake lines, TF front adj. control arms, Superwinch EPi9.0s, ARB on board air compressor, Bushwacker Flat Fenders
