Very Low MPG? Burning Oil?
Old 02-11-2010, 04:00 AM
Yankee's Avatar
If I had an engine using a quart of oil every 1000 miles, and it had less that 120k miles on it....I would be searching for the problem.
No way that is normal on modern engines, IMO.
Old 02-11-2010, 08:43 AM
JKBully's Avatar
I had a really bad oil usage problem. Like a few quarts in a couple thousand miles. Enough to turn the oil light on on the dash! I couldn't find it anywhere. I did a little searching and there is a TSB out on the 07's about the timing cover porosity being bad as a result of a bad casting, causing the oil to leak out. I took it to the dealer with a printed copy of the TSB, they got it fixed under warranty, and it's been perfect since. I will not that the problem wasn't really apparent until about 26,000 miles.
Old 02-11-2010, 09:41 AM
mbanik's Avatar
Unfortunately it seems to be fairly common with Mopar engines
Old 02-17-2010, 04:28 AM
Rhino64's Avatar
Yep ur right . Thats why Chrysler is in such bad shape, they build shit.
Old 02-17-2010, 07:09 AM
leonard08jk's Avatar
Mine burns oil to i took it to the dealer they are going to do a oil consumption test the next oil change.I changed it before i took it in.
Old 02-17-2010, 07:35 AM
Yankee's Avatar
Sigh...that sucks...but I did not have the patience to try putting an LS engine in.
Hopefully by the time mine starts using oil someone will have the conversion process ironed out.
Quick Reply: Very Low MPG? Burning Oil?
