Use of cam washers to correct caster
Old 06-22-2014 | 03:15 PM
BombJock's Avatar
Default Use of cam washers to correct caster
Was hoping someone could explain why the use of cam washers to correct caster is not preferred.
From what I have researched, for every person that says it's bad, there is someone that says their use is fine.
Kind of like the use of wheel spacers ( yes I know it's a completely different situation). Some say no, others say no problem.
Thoughts?
Old 06-22-2014 | 03:45 PM
nthinuf's Avatar
They have been known to slip with offroad use, taking you right back to the bad caster you were trying to get rid of. Some people have had good luck with welding them in place. Another downside is that you have to notch out the brackets, so if you later choose to add adjustable arms, you need to do something about the holes.
Old 06-22-2014 | 05:37 PM
SiliconTi's Avatar
Default Don't do it
DO NOT DO IT!
I had cam bolts - they never held a torque setting, so were constantly loose. Also, because the slot for them is not round, they have a tendency to "wear" into the groove, making them looser. They also caused damaged to my LCA mounts. Nothing good can come out of them.
Old 06-23-2014 | 12:38 PM
Freewill's Avatar
Install adjustable lower control arms or geometry correction brackets. You will be glad you did.
Old 06-23-2014 | 01:37 PM
TeraFlex's Avatar
Sponsoring Manufacturer
DON"T DO IT!!
Get yourself a set of front lower adjustable control arms. These will allow you with better range to set your alignment than those bolts.
Old 06-23-2014 | 02:11 PM
TxJeepers's Avatar
Or save a little coin and grab a set of metalcloak uppers. Not as cool as doing lowers but still allows the adjust for caster.
Old 06-27-2014 | 04:04 AM
BombJock's Avatar
Thanks
Quick Reply: Use of cam washers to correct caster
