Upgrading to a bigger lift?
I have the 2.5" TF coil lift with shocks and am wanting to upgrade to the TF 3" coils for a little more height. Will the track bar relocation bracket for the 2.5" lift still be ok? Will I need to upgrade anything else from the 2.5" kit? Thanks in adavance
it should all work you wont notice the difference!!!!!!!!!!but if ya only want an inch why dont ya save some money,keep the factory ride just spend $90.00 on a body lift
Thanks, I'd like to have the extra flex the suspsension lift will give me. Anyone swapped the 2.5" coils for the 3" coils? If so how much extra lift did you gain? thanks
With the 3" teraflex coils you get about 4" of lift. Now, ride quality may suffer a bit if you don't get atleast front adj lower control arms so you can increase your caster. That way your JK will handle better than factory.
I don't know if you have a 2dr or 4dr, but if yours is a 2dr you will also need to up grade your drive shafts.
Make sure to post pics after your JK grows again.
Good luck!
Good luck!
Thanks in advance for any and all advice!
Good luck!
Good luck!
I was actually wondering about a body lift. I currently have a 2.5" skyjacker suspension lift with 33s and wanted to run 35s, but am on a tight budget. Will the 1" body lift give me the clearance that I need.
I originally had a 2.5" TF BB/shocks and recently upgraded to the full 3" coils. Run 35's easily. Actual lift was closer to 4". Haven't had to change a thing other than springs. Ride is actually better than stock still but I have also added front and rear adjustable trac bars. This is just what I have done though. It does get wheeled and is my daily driver also. I am keeping an eye on the front driveshaft and so far haven't had any problems. Maybe I have just been lucky!
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
There should be the answer to all your questions.
Good luck!
