Unlimited on 37's question
#21
This is my first post on JK-Forum, and I'm kind of a newbie to the JK also, so I hope I don't screw it up.
Anyway, regarding the gussets for the C yokes on the front axles, I learned my lesson a couple of days ago: DEFINITELY reinforce those C's.
I have an '08 Rubicon Unlimited, running on new BF Goodrich 285/75/17 KM2's -- a little less than 35" -- and I spent about 40 minutes on Sunday on a very wet sandy road with lots of standing water and stumps, weaving through the pineywoods (a pipeline service road near Houston), and while I was very impressed with the JK's capability to keep going (I never got stuck), when I was finished (and covered in mud), I noticed that my steering wheel was upside down, although the Jeep still tracked straight with no wobble. I took it in to the dealership yesterday, and they told me I had a common problem with JK's with larger tires: a bent upper arm on the right C yoke (also a semi-stripped steering gear, but that's another story). They installed a new offset ball joint ($700 installed, ouch) which allowed them to re-align the wheel and re-set the steering, but now I'm concerned about the C's bending again. I've signed up for my first Jeep Jamboree in May (Palo Duro Canyon), and I don't want this happening out there.
Like you, I've done some research, and it seems that bent C's are very common. I'm ready to order some Off Road Evolution C gussets and maybe the sealed axle sleeves, or maybe some other manufacturer's equivalent parts, and get them welded on as soon as possible, once I find a shop in Houston to do it. I don't anticipate needing to change out the gears on my Jeep.
If anyone has any other recommendations or thoughts on the EVO gussets and sleeves, I'm all ears. Thanks!
#23
I'm only going to be running 35s and will be installing the EVO C2s. Sent requests for welding quotes out today. I know the included instructions recommend removing the ball joints before welding.
#25
Good luck! I'll be curious what kinds of quotes you get, since I'm in the process of doing the same thing here in Houston.
