Uneven tread wear
Originally Posted by yrubuggin
Robsjeep- is the sound consistent with wheel speed?
Tomorrow try and coast down a hill in neutral and see if the sound goes away. Another thing to do would be to put the Jeep on a lift and put it in gear off the ground and see if it still makes the noise.
Bad shocks lead to cupping, this is a different condition that M/T type tires seem to suffer from. it is like every other lug is wore down a bit more
rotating them more often helps keep it to a minimum
cupping is more like this
http://www.2carpros.com/articles/whirring-sound
That is called lack of rotation... Mud tires develop this much more easily than other styles of tread, because of the blocks, where as other treads overlap more in pattern from side to side and front to back the load of the vehicle is spread more evenly across the footprint. Ever seen wore down tractor tires? The leading edges of the lugs almost always wear down more quickly than the rest of the lugs. Normal AT tires can survive a long time on lack of rotation, but do it with mud tires and you've just 1/2ed the life of your tires. Get them re-balanced and rotated they will straighten out, but by the time they do, the fronts will be cupping again.
And the pattern shown on the site is consistent with shock wear, but the pattern your pictures show is extreme cupping for a mud tire. Been there seen that many many times. Best bet is to keep the next set rotated so they don't start cupping, once it starts, it's hard to correct. That is unless you have a hemi, then I'm pretty sure you already know how to correct the cupping with the skinny pedal and a piece of pavement!!
Pull your front trackbar and check your bolt holes in the brackets to see if they are wallowed out at all. I had the same issue with front tread wear. It will cause your front tires to woblle slightly. You wont even notice it unless you get bigger tires or you start getting death wobble.
What I saw in the picture has happened to every mud tire (on different trucks) I ever had if I get lazy and don't rotate them by at least 6k. They will chop eventually just from tight turns on pavement.
Just X them, they will be loud for a bit and then settle down.
