Under hood felt - Sound deadener or paint protection?
When moving, in-coming air flow under the hood created more pressure under the hood next to the firewall, than the possible pressure in front the bottom of the windscreen.
Also, if given an exit, hot air would flow up & out.
Removing the fender liners will force air from the wheel wells into the engine bay when driving on the road, also diminishing the amount of air through the radiator.
The best thing you can do to improve under-hood cooling is increase the air flow through the grill.
See this thread: https://www.jk-forum.com/forums/modi...trofit-235132/
A more efficient fan reduces the temperature of the water.
The fan air flow doesn’t reach the upper rear corner in the engine bay. Even if it did, it would have forced already hot air, which gets even hotter by flowing over the engine block, into that ‘pocket’, from which the air has no escape.
All of my under-hood temps on-road and off-road are way down from where they were before the addition of the mechanical fan.
By sucking air out from the rear of the engine bat, any of these would also increase air flow over the radiator.
Links --
Pacet Automotive Cooling Fans - Bonnet Fans
Pacet Automotive Cooling Fans - Roof Mounted Fans
S-Force high-performance compact fans made by ebm-papst
Cobra Valley's Duct Fan Cooling System Components
12 Volt Blowing | Product Categories | SPAL UK
---------------------Pacet Automotive Cooling Fans - Roof Mounted Fans
As for the sound insulation under the hood –
Heat insulation materials typically also insulate sound, but not vice versa. Sound insulation does not effectively insulate heat.
That layer under the hood is not – and shouldn’t be – an effective heat insulator.
The hood serves as a large area of steel that absorbs heat from the engine bay and dissipates it.
That’s why I wouldn’t use a fiberglass hood, unless it’s VERY well vented.
1) Hot air concentrates under the hood, at the highest place, from which is has no exit – next to the firewall.
2) Under-hood (engine bay) cooling and engine cooling are two different things.
3) As for the sound insulation under the hood –
Okay, so then:
1) There is a weather strip that runs along the firewall and hood, does it make sense to remove it or at least parts of it (so hood doesn't rattle) in order to let air into the cowl vent area?
2) Correct, thermostat will keep internal engine temp regulated. I'm thinking electronics such as the ECM where heat can damage electronics, ambient air for the intake, as well as helping cool the engine when under load.
3) So you think removing the felt won't help with under hood temps?
Okay, so then:
Okay, so then:
The higher the ambient temp' is, the lower the radiator efficiency gets.
If the air blown through the radiator it too warm, it doesn't cool it enough.
A more efficient fan, raises the ambient temp' at which it can still cool the water.
Leading ambient temp' air into the engine, while keeping water or dust out, is simple... a snorkel. The low-mount Rugged Ridge snorkel, for instance.
