Un-even tire wear!!!
So, I noticed my front end is wearing my tires more on the outside than the inside. I already rotated the tires, but now I need to figure out what is causing the wear. Does anyone have any suggestions on what to check and how to check it? I have a rough country 2.5" lift with only springs and shocks. I never had the alignment done after the lift because it seems to drive fine after adjusting the steering. Anyway, any suggestions would be greatly appreciated!
You simply need a wheel alignment properly done for oversized wheels to fix that problem, a wheel alignment is a must about 1k kms after a lift is installed.
Getting an alignment done is a waste of Money. Other than the caster, a lift doesn't change anything but the steering wheel position, which can be adjusted in a few minuets with little to no mechanical skills
