UD60 dimensions
I might have this completely wrong... And I can't measure as my jeep is in the shop replacing the axle upper control arm bushings.. ( shot after 12k miles ) but I think I read the dimensions are the same as factory. The axles are only wider from the rotor to mounting surface. Again I'm thinking off the top of my head here so I may be way off base
If you really needed to know & get no response you could scale it off. The upper mounts are the same width as a stock housing. Measure your current housing & then scale it off the photo.
You can also use the diameter of the rotors for scale. The specs are listed.
Yeah, I get what you're saying and have attempted to do that. I am really hoping to get an exact measurement before having the brackets I am making cut. Worst case scenario is I will have to wait for the axles to get delivered.
