TSB Update
Old 05-31-2007 | 04:05 PM
jeepn0811's Avatar
Default TSB Update
Well, I got my Jeep back from the dealer today. Had the latest TSB done for the ESP lights and stuff. Also had the through out bearing replaced again. Don't know what they changed but I went from 13 mpg on the highway to 17.5. That was 13 Highway to 17.5 city based on the dash readings which I know are not accurate due to 35" tires. But still for a 6sp, 4:10's that is a big improvement! Plus it feels much stronger!?
Old 05-31-2007 | 06:24 PM
mtnmedic's Avatar
you know because lately I have been having the esp/bas light light up as well as the brake light ding and light up...the speedo drops and then picks up again. pretty annoying, but at least it doesn't stall.
I am off tomorrow, so I am going to the dealer to see what's up, but supposedly, I am all up to date on the TSB's....though honestly, i had a sneaky suspicion that they were never actually done.
Old 05-31-2007 | 06:27 PM
nickc's Avatar
If you have a lift and bigger tires, it is because your steering wheel is not perfectly center.
Old 05-31-2007 | 06:28 PM
OBXJK's Avatar
Do i need to get these TSB updates done if i am getting a new jeep which is just now being built or are all these updates already taken care of when they build it?
Old 05-31-2007 | 06:38 PM
jeepn0811's Avatar
Not sure if you will need the update or not. Mine was in due to the clutch making all kinds of rackett. I don't think the first dealer did the TSB (for the clutch) the first time. The new dealer did the TSB for the ESP and told me when I picked it up. I didn't even know they were doing it. The service rep put my vin # in the computer and said that was the only update needed. Before that it started feeling like a dog. Now, lots of power and it flys!
Old 05-31-2007 | 06:55 PM
mslc10's Avatar
any idea what the TSB number is?
Old 05-31-2007 | 08:30 PM
jeepn0811's Avatar
For which TSB? I don't know the #'s. But the steering angle sensor is listed on the Project-jk homepage. There is a link to all current TSB's.
Old 06-01-2007 | 02:54 AM
mtnmedic's Avatar
negative, i have no lift...i'm still waiting for the OME lift to come out.
Old 06-01-2007 | 06:10 AM
BLKRUBI's Avatar
If it's just now being built, it only makes good sense that it would be updated with the corrections to fix the TSB problems instead of sending a problem out, Not that that hasn't happened before.
Old 06-01-2007 | 07:54 AM
mtnmedic's Avatar
i just got back from the dealer and they centered the steering wheel but the light still came on 100 ft after I left. So I went back and without turning the jeep off, I showed them what was going on. They now think that it is a "clock spring" in the steering wheel. he said they have had to replace some on lifted jeeps but only a few on stock one. I should have it Monday, so I'll have to see then.
