Trying to figure out lift kit terminology...
Hello all,
I've started looking around at some lift kits just trying to get a feel for what's out there and am very quickly learning that there are a lot of options. What's the difference between a kit with no arms, a short arm kit, and a long arm kit? Is there anything else is should be familiar with?I really appreciate any help.
Thanks,
Thanks,
Arms help ride quality and some flex. Depending on size of lift you choose you will have to purchase arms, driveshafts, track bars, flip kits etc.....
If your looking to have some flex without having to upgrade everything and still have the look and ride quality., stay under 3"..
Brands to look into
Teraflex
Full Traction
Rock Krawler
There are tons more lifts out there, but that's where I would start. I would also do a coil lift before a budget spacer lift
Brands to look into
Teraflex
Full Traction
Rock Krawler
FlexArms allow custom pinion and caster angles to be set for proper alignment, they also are used to re-center the axle in the wheel well for proper suspension movement.
Also when lifting your Jeep, it would be smart to buy quick disconnects so you have full flex
Btw... Long arms kits are cut and weld, but flexarms are an exact bolt on replacement for factory arms
Okay, thanks for the reply. That really helped. So would you only really need something like the long arm kit for a 4" lift? I'm probably looking to stay around 3".
Sponsoring Manufacturer
You do not have to go with a LA kit when you go to a 4". Keep in mind also that one company recommends a 4" for 37's and another will say you need a 4" for 35's. Long arms do however improve how your JK will ride/handle for you on/off road. If you have any questions, feel free to call me.
adjustable upper control arms adjust your pinion angle.
Pinion angle is the angle your differential points at your transfer case.
the more direct your diff points art your T case the less binding =less wear= smoother your drive shafts will be.
lower adjustable control arms track your axle front to back.
on the front this allows you to adjust road feel in your steering, out back it helps your wheel look more centered in the wheel well when you lift.
It does that in the front too, but the road feel and steering correction is the more important thing it does.
adjustable track bar adjusts your axle side to side.
Sometimes lifting your jeep will slide your axle over an inch or so. Some say it doesnt matter because with a solid axle vs IFS it does not really cause extra wear. But Right is right to me.
With a 2.5 inch lift and some relocation brackets you can get by with out any of the arms or bars, but it wont be perfect.
If I were only to do one, I would probably do the front lower control arms so steering is correct. Tha is the most important thing, at least at highway speeds. Second would be both track bars, and third would be upper control arms, 4th woudl be rear lower control arms.
I probably wont lift mine until I can do all of it though. I would rather do it right or not do it my self.
Good luck with your lift.
