View Poll Results: trusses or sleeves
truss
16
55.17%
axle sleeve
13
44.83%
Voters: 29. You may not vote on this poll
truss kit or sleeves
Old 03-23-2013 | 03:05 PM
Tooadvanced's Avatar
Originally Posted by janders82
Speaking of Trusses. What are you guys paying on average for the install?
I know when I do it that ill have my dad weld it. He used to weld on nuclear reactors so I think he can handle this. Has anyone had trouble with uptravel?
Old 03-23-2013 | 03:45 PM
mpkelley20's Avatar
Originally Posted by Mark
TRUSS!!!!!! Iheard that RCV's wont fit in some tubes, just something to concider if you think you might upgrade your axles one day. Personally I'd have RCV's done before sleeves or a truss.
RCV's will fit but you won't be able to run 35 spline upgrades shafts which are used with an ARB locker. . Just the standard 30 or 32 spline (can't remember).
Old 03-23-2013 | 03:59 PM
mistasparkl's Avatar
35 spline RCV's will work w/ the Nitro sleeves.
Old 03-23-2013 | 04:04 PM
RyanW's Avatar
I find the truss to be the only one that makes sense. Thick axle tubes don't do anything to help, it makes no sense. A truss reinforces everything and ties it all together to add strength. You can also reinforce all of your control arm mounts as well.
Old 03-23-2013 | 04:24 PM
jetmechabq's Avatar
I installed a truss for about 200.00. Then when I had the R&P done I added the sleeves and RCV shafts.
Old 03-23-2013 | 04:57 PM
JK-jeepit's Avatar
subscribed.
I'm also looking at doing one of these.
Old 03-23-2013 | 05:19 PM
Tripletsi's Avatar
I just installed the Nitro "hammer in" sleeves. It was a quick easy job, just deep freeze them over night and clean up you inner axle before you install them. I was welding on axle c gussets at the same time so the heat helped open up the axle tube as well. Once in place, I welded the end of the Nitro sleeve to the axle tube for extra strength. RCV's will still work with this setup as well.
This sleeve design will give your axle double wall thickness and provide a stiffer axle in less than 2 hours. Sure a truss will stiffen it up too but you'll be spending three times the amount of time installing it.
Old 03-23-2013 | 05:24 PM
RyanW's Avatar
I'd rather spend $300 and have something that definately works, as opposed to spending $100 for something that doesn't really accomplish anything.
Old 03-23-2013 | 05:38 PM
Tripletsi's Avatar
How does a precise fit double wall tube not accomplish anything? JW...
Old 03-23-2013 | 05:49 PM
Surf City Dan's Avatar
Not sure if your comment on the sleeves is your opinion or some fact that no one else can find. Please enlighten us how you can double the thickness of the axle tubes with sleeves but yet it doesn't add strength them.
