TrueTrac Install Questions/Help
I recently purchased a truetrac and want to install it soon! Here is my question.... when I install it will I need to adjust the backlash or do I just remove the stock carrier and replace it with the truetrac. I do not have a experience in removing or working on the differential but if I dont need to adjust the backlash this seems like something I could tackle? Thoughts?
Sponsoring Manufacturer
Sorry, wrong answer.
Yes, you need to check the backlash but it must match the existing backlash or premature gear wear will probably occur. Check the backlash before you remove the stock gears and match it (regardless of new specs).
Sorry, but this is still incorrect. Gears wear during use and the backlash changes over time, sometimes quite significantly. Gears stay quiet with the greater backlash because they are worn in to the break-in pattern. Changing back to a 'new' spec can create a new pattern and cause excessive wear.
