Truck lites (I'm Sorry)
Just a quick question about these lights. Keeping in mind, I know absolutely nothing about electrical. Do I need any special harnesses or wiring, other than the anti flicker harness, to run these lights in my 2014 JKU? Thanks for any and all help.
![](https://staticssl.ibsrv.net/autocomm/Content/JK-Forum/jkamicon.png)
I am running a set on my 2014 jkur and am not running the anti flicker harness and I have no flickering. I bought mine thru Northridge4x4 and they came with the harness needed to do a plug and play.
Great. So the h4 to H13 adapter works on stock light assemblies? Sorry, again it know very little.
yes. Some get flickering others don't. I have used the same Trucklites on two different wranglers a `13 and now a 14 and neither had a flicker problem. I think they are the best upgrade you can make to a jeep if you drive in the dark. I usually go to work in the dark and come home in the dark and they have been worth every penny.
Nope....degreed Electrical Engineer also...use some dielectric grease though and make sure you order the Truck Lites for the JK. It'll come with the correct connectors...
yes dielectric grease is wise. I have an industrial size tube and it gets used on everything electrical.
