Truck Lite
Old 12-25-2013 | 04:09 PM
hornetman's Avatar
Veteran: NavyFJOTM Winner
Default Truck Lite
Installed my Christmas present today, Truck Lite driving light. Went out a little while ago to check them out and the low beam is very bright, a lot better then the stock light. Switched to hi-beam and only the driver side is working....thinking I got a defective lite as there only is a pigtail plug in and she works in low just no high. Just e,ailed Northridge and going to follow up in the morning with a phone call. Has anyone else had a problems with these lights? Hope it just is a fluke and they can ship me a replacement soon. I can say that just with the low beam through I really like these lights. I just hope I don't get a lot of flashing from other drivers.
Old 12-25-2013 | 04:16 PM
scooby snacks's Avatar
No problems with mine. Trying unplugging it and re-plugging it. Maybe you have a bad connection.
Good luck!!
Old 12-25-2013 | 04:53 PM
JKatfish's Avatar
Yeah, try unplugging and re plugging. Those connectors are tight and you may have pushed a contact out....happened to me, but luckily I plugged cables together before installing the light.
Old 12-25-2013 | 09:30 PM
Jersey_Devil's Avatar
My plug is funky on one of my tl's I have to zip tie it up for the light to work. Too far one way or the other it won't work I have to zip tie it in just the right spot lol
Sent from my obama monitoring device
Old 12-25-2013 | 11:34 PM
Matthewd5's Avatar
If I were you I'd definitely return them for replacement!
mine were a pretty tight fit but they both work great
try some of that fancy electrical conductivity grease that I can't remember the name of...
matthew
Old 12-25-2013 | 11:39 PM
matthew
I've had mine in for well over a year now. Once I got the plug in place it don't go anywhere. And I got the yellow grease on there it didn't do anything for it. Only time it's a pain is if I have to remove it, it's a pain getting it set back in place.
Old 12-26-2013 | 05:46 AM
hornetman's Avatar
Thanks for inputs, just looked at the connections and the red lead contact had come loose. Used some stretch tape to help hold it in place as it didn't seam to lock down even with forcing it in place with a needle nose.
Old 12-26-2013 | 07:35 AM
So did it work?
Old 12-26-2013 | 09:07 AM
JKatfish's Avatar
Try using channel lock pliers. They hold the contacts in while you use the plier to squeeze the plugs together. Worked like a charm as the contacts are really tight. Once in, they won't come out.
Quick Reply: Truck Lite
