Troubleshooting a synergy drag link
The bend in the drag link wants to keep turning down more and more. I have tightened down the bolt and nut on the passenger side to keep it from being lose and adjusting on its own. The jam nut is still tight with no movement on the pitman arm side. I have tried taking an open end wrench and turn the adjusting sleeve on the drag link to see if there was any play in there, nothing (Is the movement of the Jeep allowing it to move?). Ive even adjusted it to where the joints were maxed out while the bar was straight.
What has been others experiences with this?
How far out is your adjuster? I've got a friend whose link rotates because the adjuster was too far out. Also, have you looked into the "anti-flop" spacers? Maybe one of those would help keep it aligned.
I'm running another brand so I can't give any comparison.
They do sell a different boot for the ends it costs like 5 bucks.
I'm doing what another member suggested, I run the stiffer black boot underneath one of the clear accordion style boots. Stays nice and flush.
Mine does this until I service with grease. The joint is a ball and socket type which through time wear and will need more lubrication.
In fact I will be greasing my tie rod, draglink, driveshaft and ball joints because I buried the Jeep mud and water.
R/
Wilk
R/
Wilk
