Trektop NX header issues and fix.
Originally Posted by dzine07
I know this have been covered many moons ago but can you tell me what the OEM bar has that the stock one doesn't? In other words "what's the big deal about the OEM bar?"
Originally Posted by mattgt5
You know how you have to basically repel off your jeep using the rear window and bar as rope to get enough force to clip the best top tailgate bar on? With the oem bar and seperate clips it literally takes no effort. It just clips in!
How much?
I don't remember if your the guy that had an older oem bar or a new 2012 one. Which do you have?
I had mine in the sun too and it was 85 and sunny. I was confident i was safe but guess not.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=317215"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=317216"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=317217"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=317218"/>
Doesn't piss you off when you hear. Mine went on great ,I had no problems here, fits perfect. I'm waiting for someone to say I put mine on in 20 degree weather when it was snowing out and had no problems. It's a 50/50 shot if your going to get one that's a bitch to put on or not. I finally got mine on correctly and now I'm scared to touch it. I'm going to let it stretch out for a week or two before I touch it again. I sold my OEM top so im going to have to deal with the rear window channel. Hopefully it get easier over time too.
That's a good question. I'm sure you can and I'm sure its pricey. I'll stick with the one from besttop for a while if it doesn't loosen up then ill deal with it. The hole top is going to loosen up over time. Id rather have it tight now and loosen to fit then have it fit good and be too loose down the road.
