Transmission cooler mounting question
Having a bit of a cooling issue on my LS. Only thing in front of the grill is the winch control box, down very low. All original skirts and fan shroud are used with aluminum radiator. I do have a transmission cooler mounted in front of the radiator as normal. Was wondering if I could mount the cooler down low horizontal to radiator basically behind the lower rail the the cooler is now mounted to. I have included a pic of the way mine is mounted, found on the internet as I did not have a pic. Will this placement still work for cooling of the transmission? Reason I am looking at it is to get rid of the cooler being right in front of the middle of the radiator. Maybe it wont make any difference but not sure, so I thought I would see what all of you think.
I can see mud below your cooler on your radiator. Take the plastic off the top and bottom and give it a good rinse. Very well good be as simple as that. I've also heard of RV misters working well. Put them next to your fan so it shoots a cool mist.
Actually not a pic of mine, I did not have one and found this one on the net that is mounted like mine. But I have power wash the a/c condenser and transmission cooler out before reinstalling them.
I get the same over heating issue on my 3.8l. I put hood louver on hood, but still over heated and had coolant coming out of over flow tube. Need to change fluid and see if that helps. If not will buy small round one saw some where. Or go mech fan.
When are you overheating? How many miles? Ever done the thermostat simple fix two bolts cheap part. Pull the plastic off the bottom off your rad and rinse it good. There's also plastic on the front dirt hides behind there. Rinse both sides and rinse good. I don't suggest a power washer. You may have to take the fan shroud off the back to get in there good.
Yeah I have same cooler and have NO issue overheating in SOCAL 100+ temps outside.
If the OP is using a stock radiator with an LS motor his overheating issue may not be because of trans cooler but because radiator is to small.
