Transfer case shattered by front drive line wobble
#61
#62
Without having the driveshaft on a machine to duplicate both speed and angle, there's no way for me to tell how narrow that window is......or even if there IS a window. I'm certain there must be, because if not, we'd be seeing tons of failures like this by now....I mean as many lifted Jeeps as there are with replacement U-joint driveshafts.
Perhaps there was an issue with a flawed TC casting that contributed to the problem?
Was the DS greased regularly and recently? I'm running JE Reel 1350s front and rear and I can tell you that with my skids it's damn near impossible to grease the front CV. In fact I just got a pair of 1350's that have std grease nipples in one of the caps which I should be able to easily get to, even with the skids. The needle fittings in the yoke are damn near impossible to get to (with skids). I'm going to drop the skids, pull the driveshaft and install the new u-joints. And while it's down I will have it balanced.
FWIW I drive 75 all the time as that is out speed limit. I've had no problems.
#63
When you ask to get your shaft balanced at, say 75 mph, the tech doesn't ask about your transmission, engine rpm or TC ratio. None of it matters.
#65
I don't believe you are correct here. All you really need to figure driveline rpm is your tire diameter, gear ratio and speed. The standard calc is done for 60 mph and then you apply a multiplier, such as 1.25 to get your speed at 75.
#66
#67
If engine is turning 2500rpm going through a stock transmission then no matter what you do in the axle the drive shaft speed is the same.
What you are changing is the speed of things passed what you change. In this case he has larger tires. If he changed nothing but the tires he would go faster for a given transmission gear and engine rpm than before because the circumference of the tire is larger, however he would loose torque. So he changed his diff gears so that with the given transmission gear and engine rpm he would be going the original stock speed. So again the only thing that he changed is what is happening in the axle
Drive shaft speed in this case was stock!!!
#68
#69
PERIOD
When you change Diff gears you are changing axle and tire speed for a given transmission gear and engine RPM
Think of your jeep on a lift. Ok, now you have a stock setup. Start jeep and select any gear and let it just spin freely with the engine idleing. Now imagine the same setup with different diff gears (higher or lower). Engine rpm is the same. Transmission is doing the same thing. DRIVESHAFT is doing the same thing. Now because you have changed the Diff gearing, the axles will be either faster or slower depending on the change you made to your gear ratio. Also your tires will be affected the same way.
Now you put the jeep on the road and you have the same effect. Only the tire and axle speed changes with Diff gear ratio changes!!!
#70
No matter the axle gear ratio the drive shaft can't spin faster than the transmission!!!!
PERIOD
PERIOD
