Tranny cooler?????
If you are asking about tranny coolers on Wranglers with automatic transmissions:
It's not within the stock radiator. It's in front of the stock engine coolant radiator.
It is, however, an integral part of the A/C condenser. The bottom portion, I believe.
You add the aftermarket cooler in series with the OEM cooler.
There are a few write-ups on this mod. It is easy to do.
lv jk,
You beat me to it by 1 minute. I have noticed simultaneous posts happen a lot.
lv jk,
If you really want to knock your trans temps down install the big B&M with an electric fan. It's rated at arounf 30k GVW and costs between 220-250.. It took my trans temps down at least 55 degrees. I did not run it in series with the virtually uselss stock trans cooler per instructions from High Impact Transmissions. There is NO comparison between the big B&M and a little 50 dollar add on.
