Traction control wont go off 2013
Old 01-13-2014, 03:59 PM
ride4life1990's Avatar
Default Traction control wont go off 2013
Just recently installed a 3.5 re lift a few weeks weeks ago. Everything went together great drove on it for almost 3 weeks on stock tires. Then I installed my 35s not it pulls to the left real hard and traction control light won't go out. I'm not running tpms have a procal. I straightened the wheel with the procal several times can't get the light to go away. Light came on first 10-20 miles on new tires and wheels. Need help!
Old 01-13-2014, 04:17 PM
TURTLECON's Avatar
Little confused... How do you center a steering wheel with a tuner? Get under the jeep and adjust the turnbuckle on your draglink to center the wheel. ESP light won't turn off?
Check your sensors. How many miles? It's a 2013 should still be under warranty. Check all your bolts again on suspension and torq to specs. Are you using stock wheels? If so, are you running spacers?
Old 01-13-2014, 04:33 PM
The procal lights up front turn signals to tell u which way to spin drag link. Both turn signals light wen centered. I have aftermarket steel wheels. Nothing changed with suspension before light came on. I was very careful will all the wires when I installed the lift
Old 01-13-2014, 04:37 PM
JK08MCS's Avatar
I didn't know my Pro cal did that. Here I've been jumping down and up like a monkey, then drive a little bit. Mines an 08
Old 01-13-2014, 04:41 PM
Ya lol but u have to have ur tires straight
Old 01-13-2014, 04:49 PM
TURTLECON's Avatar
Hmmm... I'm wondering if ESP has a dedicated fuse might've burned out?
Have you tried bringing jeep back to stock to see if maybe it's the tuner causing the gremlin?
Old 01-13-2014, 05:03 PM
Ya no luck it only has 7500 miles to
Old 01-13-2014, 05:09 PM
Billbikes's Avatar
Possibility of a damaged wheel sensor? You say it happened after you added new tires.....
Old 01-13-2014, 05:17 PM
Ya new wheels and tires
Old 01-13-2014, 05:30 PM
ezdoesit06's Avatar
Something isn lined up right when you centered the wheel and now your steering angle sensor is noticing the difference and throwing on that light. Adjust it properly or have an alignment done at the dealership so they can get it right and clear the light for you
Quick Reply: Traction control wont go off 2013
