Traction Control Light
Ok so when I am in 2WD and 4H the traction control light does not come on, but if I put it in 4 LO the Traction Control light come on. Does anyone have any ideas.
The reason why it turns off is for the most traction and most control possible. you should try to drive your jeep in 4hi with traction contol on then with it off and you will see why. but it will only make a difference if you spinnig the tires. give it a try in some mud. it works the same way in 2wd try to drive on slick terrain in 2wd with trac contol on then off and see what happens. Huge difference. you will have alot more control over your vehicle with trac control off.
Confused?
Seems backwards to me. Why did they (Jeep) make it stay on al the time if it's better (more control) with it off? What is it's purpose if not to give you more control? Thanks
it does help in everyday driving when the roads are wet or slick and you go around a corner not expecting to loose traction. but it doesent help when your on the trail at least in my experience.
