Traction control kicks in on turns with new 35s
Old 04-07-2014, 04:07 PM
mikepov's Avatar
Default Traction control kicks in on turns with new 35s
Recently lifted my 07 and put 35s on it, and ever since these mods wen i make an exaggerated turn either way such as going around a jug handle or a long curve on a street the traction control kicks in any ideas? I thought it was just cause the new tires had to break in but its been about 3 months and it dosent happen as often but still happens ......help please ,and o yea it happens on dry pavement obviously
Old 04-07-2014, 04:09 PM
stevo1371's Avatar
Did u adjust the drag link before moving the jeep after the install?
Old 04-07-2014, 04:23 PM
Rebar-7's Avatar
Is your steering wheel centerd ?
Old 04-07-2014, 04:53 PM
Philip *AZ*'s Avatar
Yep, do what they said. Once I got mine out and crawled it kinda hard a couple times it quit doing it as bad, but I installed a switch to turn it off. I would check what the first two stated first. Those are both causes, especially the steering wheel.
Old 04-07-2014, 07:09 PM
Ryan0260's Avatar
I would check this first.
Old 04-07-2014, 09:04 PM
mbaron142's Avatar
I'm going through the same issue! The steering wheel was just centered and the wheels were aligned again. I'll keep you posted if I get any head way on this!
Old 04-07-2014, 09:23 PM
Mine will still do it if Im driving aggressively.
I hope you get it figured out. I cant give any good input because my issue went away on its own pretty much.
Old 04-08-2014, 02:09 AM
jtphoto JK's Avatar
You also have to reprogram for the tire size difference. The difference in tire rotational speed between left and right is what sets off traction/stability control. The taller tires have different rotational values.
Old 04-08-2014, 02:29 AM
Mark Doiron's Avatar
When you lift your Jeep it throws your steering wheel centering off. The more you lift, the more so. To correct this you need to recenter it. This is done by adjusting the length of the drag link. Until properly centered, your Jeep will think it is skidding during some turns.
Here is how to do it--easy, 15 minute job. If you pay a shop to "align" your Jeep because you lifted, this is all they will probably do (while charging you full price) ...
http://wayalife.com/showthread.php?3...-End-Alignment
How high did you lift, BTW?
Old 04-08-2014, 05:57 AM
Jeepstin12's Avatar
It happens even with the steering wheel centered. Mine did it just yesterday. High cross wing, around 90 degree turn and hit a pot hole. Jeep skootched sideways a bit and wallah! Light came on. Stayed on for about 2 miles. Turned the jeep off then back on and it went out. Same scenario as the other two times, less the cross wind.
Quick Reply: Traction control kicks in on turns with new 35s
