Traction control kicking on when turning right?
Ok at a loss again. Going around a sharpish highway off ramp quickly causes the traction control to kick on.
However I can whip the Jeep around a corner on surface roads and it doesn't happen.
Any ideas guys?
4" Evo w/DL flip and 35's
Sent from my LG-LS980 using JK-Forum
Any ideas guys?
Tires are about half worn and about a year and a half old.
Just started happening about two weeks ago. Did the PP drag link flip and track bar mount , rotated tires and centered steering perfectly.
Again my question are geared more towards the tread life.. cause with the Mud terrains.. there was about 30K on all but two tires.. and when it rained.. we hated it.. and swapped them with another jeeper. Trac control kept going off like crazy.. no matter what direction etc we drove. If you feel or your tires are more slick than not.. I would really start to keep an eye on them.. But have you tried to rotate your spare or a tire with more treads on it to the troubled area just to see if that makes a difference..
I had similar issues after my DL flip and synergy drag link was installed. Ended up being an issue with the torquing on the DL nut. Check the torque an make sure there isn't any play in the insert.
This just started out of nowhere right after the DL flip.
Well again.. it was a Mud terrain issue with us.. MtraXX might be onto something.. say.. when was the last time you had service done on the diffs?.. did you know that mopar requires an additive.. unsure what.. but Valovline ran through a checklist on this.. if whomever did the diff fluid.. could have used inferior fluids.. or simply did add the additive.. just throwing things out there.. but heh.. sometimes all it needs is a good swift kick.. Just disco the battery clean the terms for a rest, then check..
