Traction Control Coming On
Old 04-25-2016, 01:47 PM
jchappies's Avatar
I get that on certain on\off ramps and I'm only on 35's. It seem with the bumps and the way the curve throws me in the turn I get it on the same 2 ramps every time unless I slow down enough so it doesn't do it.
Old 04-25-2016, 02:04 PM
Smudgeontheglass's Avatar
Since the tone rings are on the actual wheel hub, you do need to program actual tire size and gear ratio. If you don't, any time you have a minor speed difference (such as cornering or going over a bump) it will put the system into the stability control and ABS mode to try and compensate. I've never had an issue with mine as I programmed it before even driving with the bigger tires.
Old 04-25-2016, 07:29 PM
T&ERun's Avatar
Thanks man, but I did this too. Good thought though.
Quick Reply: Traction Control Coming On
