trackbar preferances anyone?
i have searched around for a while and really cant find if there is a preferance of Trackbars or are they all the same? i only have the 2.5 inch procomp lift and i know i am probably going a little overboard but i am considering f & r adjustable track bars and new adj control arms. maybe all 8? I want the adjustability so i can get rid of the "flighty" highway steering and i got a little coin to spend.
any suggestions?
any suggestions?
front and rear JKS track bars here also. no issues.
also u really only need front lower control arms to fix your "flighty" steering. your caster angle is prob below factory 4.2 spec. yes u can get all 8, but u dont need them to fix the caster.
edit.. well for caster u need EITHER front lowers, or front uppers, but i would get lowers because there easier to adjust, and the stock ones can take a beating down there, and an upgraded set is alot stronger than the stockers.
I have a TF front adjustable trackbar and LCAs. Works fine and steering is great.
If you have a little cash you might consider putting in a track bar brace. JKS has a couple that also relo the steering stabilizer. It gussets where the track bar attaches to the axle and is low cost. Just a thought.
