Track bar bolt replacement
For a friend who is replacing the 14mm bolt and changing it to the 9/16. Question is do we need to jack it up to take the track bar off or just do it with weight on it? Don't want to get teeth knocked out.
You're good on the ground. Just need a buddy to turn the sterring to line up the front bar and push on the rear quarter panel to catch the rear swaybar. Just did this upgrade myself a few months ago. Make sure you use grade 8 hardward and stover nuts to lock things down.
