Trac Bar Control Arm HELP ASAP
I bought and am installing Teraflex control arms and JKS trac bar. After installing the rear control arms both my JKS trac bar and stock trac bar are now hitting. I have a slight bow in the springs and the control arms are fully retracted . Is there something I'm doing wrong I NEED HELP it's in the air at a friends house.
whats it like sitting on the ground?
I had the same problem and my spring was not seated correctly. I had to loosen damn near everything to rotate it, once done no problems at all.
How much longer than stock are your lower arms, 3/8" is a bunch, and rotating the pinion (for the driveshaft) can make it seem worse but once you get everything seated properly it shouldn't be any trouble.
Then I saw the spring was 45 degrees rotated the wrong way (user installation error), rotated it back and forced the top with the isolator and spacer over about 1/2" to where they should have been and it's been fine ever since.
I had to disconnect the OME shock (short travel model), the wires (unplugged the holders), the sway bar link, and the brake line bracket (I have extended Crown brake lines), and track bar to get the thing to droop enough (3-4" past the shock limit) to rotate the spring.
Man, OME long travel shocks and massive droop here I come!
Think I would add Currie spring retainer kit (as suggested by David at Northridge).
