TPMS Sensor?
When I went to 35's, for some reason the shop had them inflated to 35psi, which was crazy. After lowering them to 26psi, the TPMS warning kept going off every time I started the Jeep.
I had thought that the computer was complaining because of the lowered pressure, but the dealership informed me that the warning is set to go off if any tire varies from the other tires by 6psi. Since my spare tire on the back was still at 35psi, that would be the issue
So, if you're lowering your psi, remember to do all 5 tires, not just the 4 you're riding on
Can I run new rims and tires without the sensors?
I really don't want the head ache of swapping them out from my stock rubi rims and tires, plus I'm thinking I can sell the stock rims/tires for more with the sensors in them.
What a royal PIA these thins are. You can run fine without them but your tpms light will be on. I think some states may start inspecting them in the future, kinda like a smog check. If' they're not working you don't pass. I would keep at least the sensors if you sell your tires.
I don't know if they read pressure differences or just a low sensor but I changed out my wheels/tires today to stock Rubicon BFG's without sensors and drove them around to make sure I wuold like them. No light or bell sounded. Then I remembered that my stock spare with sensor was still mounted on the back. Maybe the one tire with TPMS is enough. I'll know tomorrow after a 200 mile road trip.
