TPMS question
TPMS question
Hey everyone, if I put a set of OEM wheels from a 2015 JK on my 2011, will the TPMS system pick up the new sensors without issue? Or are they different, or do I need a scan tool? Thank you in advance!
You might get the sensor indication light to come on.. an a quick disco of the positive cable to the battery would reset these or have them professionally reset via a tire shop or if you actually have the tools to to do it yourself all the better. but typically these should receive a signal. I mean we swapped tires with a fellow and had no issues, but I did check each tire upon install just to see if the sensors were operational and the PSI was reading correctly.
