TPMS question
TPMS question
I have an 08 JK unlimited Rubicon and just bought a new set of wheels/tires. Can I swap the tpms sensors myself or do I need to pay a shop to do it? Any tricks out there?
Thanks,
Thanks,
Hold the tpms while unscrewing it from the top making sure you dont drop the tpms sensor inside the tire.
or you can just ask Discount Tire to drop the sensor for you they shold do it for free as i work at discount tire myself, might depend on how busy they are.
and, if your '08 has the aluminum nuts holding the valve stems, you may have to replace the stem/nut because of corrosion.
The newer sensors have rubber stems and no nuts to corrode.
If you opt for new sensors, investigate! The new (rubber stem) sensors are a different frequency than the old ones. Some forum members have posted that they installed them and they were (eventually) automatically recognized by the jeep. Others say they had to be flashed at the dealer (or tire store).
Installation-wise, the sensor simply sits against the rim, held in place buy the nut on the aluminum stem or held in place by the rubber stem without a nut.
If you keep the old sensors but need new nuts and/or stems, you can buy them on amazon or some tire stores. I got valve stems on amazon and "service packs" at a VIP tire.
"Schrader 20013 TPMS Service Pack" and "Schrader 20020 TPMS Service Pack Fits Stem Only"
