TPMS Question
TPMS Question
If I don't put TPMS sensors in the aftermarket rims that I plan on getting will it cause any problems other than the low pressure light being on all the time?
The dealer probably wont do anything for you, but an AEV ProCal will take care of it in about 5 seconds. If you dont do anything the light will be on whenever the jeep is running
x2 on Superchips. Get a good performance boost and other cool features as well. The dealer cannot disable the TPMS system/warning light. They can only change the tire pressure that triggers the warning (lowest setting of 28 PSI).
A TPMS fault will not cause any problems other than part of the instrument display will not dim.
I went to the dealer a few days ago to have it turned off. The shop that put my new wheels/tires on never put the TPMS's in and I wanted to know what all was affected. The dealer said the light will be on and sometimes it will flash. They also said they couldn't disable it (I assume it's due to liabilities nad such). But I'm ok with the light being on now that I know nothing else is affected by it.
